ABS Rotor on NON ABS 240sx
Silvia92
Car: S13
Can I run abs drilled slotted rotor on a car that does NOT have abs (non abs)? I mean I just want to use the rotor, do not care for the sensors since i Dont have them. Do i have to worry about the type of pads, caliper (pad carrier), or clearance of the rim or anything? Can I just use it without the ABS functionality?
whats the difference, all i really want to do is just run it.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
the ABS rotor is a bit bigger than the non ABS rotor. it will rub on the caliper bracket. you can buy drilled and slotted rotors for non ABS applications.
Silvia92
Car: S13
thanks! that answers my question perfectly, so that means if I got the calipers too it would work then.
Its just that ABS has more selection of rotors.
NISSAN240SX12
1991 Toyota Supra
make sure you get the calipers and mounting brackets
