ABS or TCS?
LarryO2020
Car: 1996 q45T
I was driving my 1996 Q45t today and the ABS, TCS, and Slip lights came on. When I shut off the car, the ABS actuator continues to run. I looked in the online tech manual but couldn't find anything in the troubleshooting area about the actuator continuing to run. Any thoughts on what the cause is ??? thanks. Larry O
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
First off are you in America (USDM) or anywhere else (JDM, ADM, RDM...)
How do you have a 1996 Infiniti Q45t (Touring)? Do you have a rear steering rack and a larger Power steering reservoir with a electrical harness on top of the cap?
Have you run the diagnostic found in the service manual that came with your Q? (Or should have)
Does the ABS continue to function despite the ABS light being on?
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
ABS relay is your likely culprit.
