abs or not?
SR22DET
Car: cars cars girls cars
hey i was wondering if it's possible to use the 89-94 ABS rotors on the non abs same years... i work at a parts store and can get the slotted rotors for like 30 bucks a pop but they're for the ABS model and the (front) rotor is a little bit bigger but not that much but i was just wondering because i dont want to spend money get my hopes up and then not use them thanks in advance
SmithSR
Car: 240sx
Yes, easily.You could if you wanted to order abs calipers and rotors or just rotors(size difference is very small I forget the number in standard)
kamikazestorm420
the non abs calipers with the abs rotors did not fit.
i put abs calipers and rotors on my car.the rotors tho .. you will have to cut out the heatshield or bend it out of the way
SR22DET
well the thing was i wanted to get the rotors so i dont have to go to the Z brake swap because i'm lazy like that plus i dont have like 500 (rough estimate on rebuilt stuff) to spend on brakes right now ... thanks a lot for the info though
InsanityInc
No, you cannot. The ABS rotors are a fair bit larger and rub the calipers.
kamikazestorm420
ya you cant use the abs rotors unless you have the abs calipers.
and the pads for abs is alot more surface area than the non abs ones. same with the calipers too.
