biggie wrote:1. Tires really should not affect the ABS system, especially if they are the same on each side to side, shouldn't matter on front to rear.
2. Weird they had all the same tires on front and rear. Wheels and tires should be staggered on a coupe.
That's probably what I would have done if there were to be a long interval. But I just parked the car once the problem started, and reluctantly drove my weekend car daily.joe603 wrote:Did you try disabling the VSC system? You could also remove the fuse for the ABS until you have the correct tires on the car...
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
