ABS LSD on NON ABS shaft???
driftneil
Car: A pile of cars.
Hello again Nico, real simple question...I have an ABS limited slip diff, and I have a aluminum non abs shaft. Will this work, or are the LSD's different sizes?I know the shafts are different sizes, from abs to non-abs. So I assume the lsd's are the same size.....Someone that knows for sure chime in, PLEASE.If no answers, I will swap the shaft tommorrow. And size the lsd's up after.Thanks all!
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
different sizes
ss82480
Car: 1992 240sx Coupe
From what I know there is a slight difference in size. I have been running an ABS J30 diff in my non-abs car for 4 years with no problems. As for the one piece shaft, not sure how it'll fit, as the stock one is a tight fit even with the bend in the middle.
driftneil
Wc240 wrote:different sizes
Is the ABS bigger or smaller, and will it work, or not?
ss82480 wrote:From what I know there is a slight difference in size. I have been running an ABS J30 diff in my non-abs car for 4 years with no problems. As for the one piece shaft, not sure how it'll fit, as the stock one is a tight fit even with the bend in the middle.
Are you running it on a s13 or 14?
ss82480
On an s13, sorry.
driftneil
No sorry needed bro, it all helps.Atleast I know the abs lsd is bigger.
