ABS Light!
fairladyzz
Car: 1992 Nissan 300zx n/a and 1990 Nissan TT
i searched and found nothing, so thats why im posting..so just today my ABS light came on along with this buzzing clicky sound from the right rear wheel inside the car,,how can i fix this? oh the buzzing sound went away after an hour but the light is still on.
Z32TT
Car: 90' 300ZX TT
abs is bad get a new one its right behind the pass. seat under the plastic hence your noise
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Yep. The buzzing sound is the ABS motor running. It usually only operates when it senses wheel slippage. For a temporary fix, unplug the ABS fuse. That *should* kill the idiot light (don't quote me on that). After that, the most likely culprit would be the ABS computer sending a false skid signal to the motor.
fairladyzz
where would i find the abs fuse, i checked the engine bay there is on 20v fuse it the black fuse box but is fine, where would i find another one..if the motor needs replacement is it fine to just not have it at all?
robsZ
Car: 1992 Nissan 300zx N/A
I had the same problem, it was the abs relay, bought a new 1 and it worked fine... here is a link with good info
zer...relay
fairladyzz
thanks man fixed the problem!
turbo110
Car: 1995 Pearl White 300ZX TT
Hi! I know this thread is ancient, but could someone give me a part number for the ABS relay? Is it 47605-17V03 or 47605-17V10, or something else? Thanks!
turbo110
For the record, I ended up with NISSAN OEM-ABS Relay 4760517V10 and installed it last June. Fingers crossed....
DCaff300ZX
Car: .
1993 CRP TT- Modified
Zombi-licious....but, at least there's confirmation this solution works for this problem!
