93j30t »
https://forums.nicoclub.com/93j30t-u38330.html
Wed Apr 12, 2006 8:24 am
yea i've replaced mine...
remove with a flat head to wedge and remove the plastic housing. then you'll have to use the jaws of life on one of them (i believe it's the one in the back) and the first one you can remove by itself... replace them both if you can afford to. i was holding out by hitting the casing really quick after i shut off my engine, but i didn't want to continue and burn out the abs system.
