ABS light on + sub not working, 01 i30
rob1224
so i just got a 2001 i30, 200,000 miles 2 owner car, everything seems fine except the ABS light is on, it does need a tire rotation and alignment, brakes, rotors, and calipers all around..so do you think that'll fix the problem or is it a separate problem all together?
Also the Sub isnt working and i looked online and this seems like a common problem with the bose system, every other speaker works perfectly and there doesnt seem to be anything disconnected from just taking a glance at it in the trunk, is there a common problem for this?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
ABS light can be caused by faulty relay, solenoid valve, wheel sensor, etc. Refer to link below, starting on page 48 for Diagnostic.
http://www.nicoclub.com/FSM/maxima/2001/BR.pdf
Have you tried ohming out the sub? Are you getting output from the amp?
rob1224
wow thats quite a few things that can be wrong with it, time to do some research haha, ill try ohming the sub sometime this week or next week at the schools garage.
