abs light on, no overdrive
General discussion area for the U13-chassis Altima
ejtbullhead
Car: 93 altima gxe
ok, just bought my 93 altima gxe about 2 wks ago, everything was great until thursday afternoon. while driving home, the abs light came on, at the same time the auto (yuck)transmission kicked out of overdrive(won't turn back on)and now the power windows, and seat belts don't work(all seemed to stop working at the same time).(all worked fine prior to the abs light coming on)now the car seems nutless especially on takeoff. are all of these problems tied together, do they share a common ground, or hot wire? any thoughts , or suggestions for a possible cure? i have already tried resetting the ecm as suggested on another nissan forum, but it made no difference.help please
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I'll pull my schematics and get back to you.
ejtbullhead
Car: 93 altima gxe
problem fixed, in the fuse box under the dash, the bottom left fuse marked "electronic parts" is the abs, tcm,windows, and seat belts! which by the way is something that 15 different Nissan dealerships said weren't tied together in any way shape or form.......so, after 4 hours of diagnostics it ended up being a fuse that was corroded, basically a 2 second fix. now alls well again!!!!
Return to “1st Generation Altima Sedan (1993-1997)”
