TxGuy67 »
https://forums.nicoclub.com/txguy67-u10905.html
Wed Dec 03, 2003 9:05 am
I did a search from an old group, here's a quote from Carlos whose on this board somewhere. He also has a website devoted to his J30, once I find it I'll post it."It takes about one minute to fix. You can't let the ABSpump run like that because it will burn up the pump or drain yourbattery. The ABS pump is expen$ive! Just replace the relays.
There are two relays in the engine compartment - by the firewall -passenger side. There's a black plastic box with the two relays inside -the box is next to the ABS pump . The relays are square, plastic, one ofthem has a cross on top. I replaced both of the relays because I didn'tknow which one was the bad one. The cost was about $40 for both relays(from the dealer of course)" It seems to be a diy but I had mine done at the dealer for about $150.00Carlos if you read this, don't be upset I quoted you....JJR
