ABS Light is On
Bohemiangod
Car: 1999 Chevy Camaro V6/5Spd and a 1990 Nissan 300ZX Twin Turbo!
My 300zx's ABS light is on and will go on after driving in 1st for 5 seconds. When i first start the car there is no problem, then I shift into 1st and go foward and I hear a buzzing sound and the light clicks on. Itll will sometimes buzz again and click off during driving only to come on again. Any ideas?
Exar-Kun
Car: 2005 350Z
Check your fluid level, it could be that the jarring of shifting into gear is causing the fluid to drop below normal...
Other than that..check out your abs sensors to make sure they're all A-ok. It could be that the vehicle is check it;s ABS wheel sensors when you start moving and one of them isn't operating correctly.
-Chet
