ABS Light -- Already Replaced ABS Relays Without Success
Pogophil
Our J30's ABS light is on. We replaced the ABS relays, since it's a relatively cheap and easy fix (see link below), but that didn't solve the problem.
http://www.fuzzycats.com/docs/ABS_indicator.pdf
I recently bought an ABS module off ebay, but I'd prefer to play it smart. Any thoughts?
Thanks in advance!
driverdriver
Car: NICO's longtime resident Canuck!!!
If its not the relay, it could be either the module, sensor or wire.
Are you getting any codes?
Pogophil
No codes. How would I diagnose?
Are there any writeups on swapping the ABS module?
braintreeauto
Car: 2001 Infiniti I30
Any idea where the ABS relays are located in a 2001 Infiniti I30? There is a plastic box with relays that has two listed on the lid but the plugs are empty (with no connectors). This is towards the front of the engine, anywhere else I should look?
