ABS issues... dude no brakes!!!!
tek747
Car: 95 nissan 240
I just got my car running, bled the breaks button everything up got her out of the drive way nice and slow taking it all in and put her on first, then second then as i reached the end of the road i realized "NO BREAKS!!!" pumpt several times breaks started to grab alittle but i was getting close to the neighbors so i used e-brake.Any clues? Can i bypass ABS somehow? Im right there, I cant belive it. Your input is really appriciated guys. Thanks
Joe
your brakes will still work without your abs module hooked up to anything.
it sounds like you need to keep bleeding your brakes
why were you bleeding them to begin with?
tek747
Car: 95 nissan 240
I figured, anytime i unhook brake lines clutch lines etc.... i bleed them. I just did the conversion. I just need to keep bleeding?
Joe
yes
tek747
Car: 95 nissan 240
Yeah.......... i re bled all the line and i still have nothing. I thought i had it, but evidently when i turned the car on pedal went to the metal!
Joe
how are you bleeding the lines?
tek747
Car: 95 nissan 240
FL, FR, RL and RR all at the calipers!? I have a feeling your laughing at me.(LOL) Please dont tell me that theres a different way!
Joe
well first of all youre doing it backwards. you start at the farthest away from the master cylinder.
RR, LR, RF, LF.
secondly, i meant HOW? like are you gravity bleeding? vacuum bleeding? pump and open method? etc
tek747
Car: 95 nissan 240
Pump and open------- i guess the old school way?
tek747
Car: 95 nissan 240
By the way............. NICE 240 that thing is hot!
Joe
theres nothing wrong with that i was just curious.
make SURE you dont run the master dry
you can always try gravity bleeding too. it takes longer, but you can do it solo and it works just as well.
basically jack the car up, remove the wheels, open 1 bleeder, wait. the fluid will drain out and just wait till its new, clear, not-bubbly fluid.
tek747
Car: 95 nissan 240
Hey man, i appriciate it byt the tons! I will resume tomorrow after work and ill post up on the results. I hope this takes care of it.... thanks Kamin!
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
tek747 wrote:I figured, anytime i unhook brake lines clutch lines etc.... i bleed them. I just did the conversion. I just need to keep bleeding?
What conversion? Skyline/Z32 calipers or are you referring to the engine swap? If it is the calipers, make sure you didn't install the calipers on the wrong side. If the left is on the right and the right is on the left, your bleeder screws will be on the bottom instead of the top and air gets trapped in the caliper.
tek747
Car: 95 nissan 240
Sorry guys, having a computer issue too. Anyways, ive always had my conversion (wrong i guess) but ive never had this problem. I have bled them again ......... ive changed out the brake booster also...... nothing! Im beginig to think it may be my MC? Could it be? I have looked for leaks and there has been none present. So i came about the booster since it resorts to air pressure... nothing! MC, would you guys think could be the culprit??
tek747
Car: 95 nissan 240
ItzGenX...... RB conversion, runs nice! Could run better if i could stop. LOL
Mistaken
Car: 93 240sx Coupe
Get a friend and have him sit in your driver seat. Pump 3 times and hold the pedal down. Crack the bleeder open, air/fluid will rush out... when it stops close the bleeder. Your friends foot should be on the floor at this point... have him pump and repeat until you get only fluid. If you put a small piece of hose on the bleeder and put it in a cup of clean brake fluid it should show air bubbles and then will be a fair safe incase your friend takes his foot off the brake before you close the bleeder.
Start with the furthest wheel from the brake master cylinder and end with the closest.
O yah a third friend might help to keep the fluid level in your master cylinder up.
It could be a different issue but i thought ide throw in my 2 cents and tell you the one of the easiest ways i know to bleed the brakes.
tek747
Car: 95 nissan 240
Thanks Mistaken!! I appriciate your input,. but, i still have that issue......... no air bubbles, nothing but clear liquid!
s13point5
Car: 89 240sx
could be a bad master or slave
tek747
Car: 95 nissan 240
bled the crap out of it today at lunch.... from just about every orifice (he-he!!) And got the pedal to have some resistance! But when i turn the car on ......... pedal goes to the floor.
RB_Seth
Car: 92 240sx RB25
91 240sx LT1
95 240sx 280k mile DD
have you tried bleeding the ABS unit itself and then the calipers? If that doesnt work you prolly have a bad master cylinder - this happened on my dads car
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
try bleeding the system while its running. The brake booster will put more force pushing more air out of the system. I have had to do this on a few cars.
carmo
Car: 92 Accord, 90 Civic, 89 240sx
Make sure the ABS actuator (block w/ all the lines running to it) is electrically disconnected. Supposedly this is a must for bleeding newer Nissans although i've never had a problem. Good luck....
