troy3399 »
https://forums.nicoclub.com/troy3399-u138578.html
Thu Sep 03, 2009 6:16 am
If the ABS light come on check for the code. I think ABS computer inside the trunk. Make necessarry repair, see if that fix. Below is the intruction how to read ABS codes.
Note:Module may need to be removed to expose LED. However for modules in the boot side finisher, there should be a small hole which can be used to access the LED. Only one code is stored at one time. to get next code, repair and retest1 Drive the vehicle faster than 30kph for at least 1 minute.2 Leave the engine running.3 Read codes as described in the Code Format Description below.4 Press the continue button to enter the code numbers and get the code description.Code Format DiagramCode Format Description• Only one code is displayed at one time.• The code is a straight count of flashes, 5 flashes represents code 5.• A long pause separates each repetition.
Code No.
45 Front left actuator solenoide valve41 Front right actuator solenoid valve55 Rear actuator solenoid valve25 Front left senor ( open circuit)26 Front left sensor ( open circuit)21 Front right sensor ( open circuit)22 Front right sensor ( open circuit)35 Rear left sensor ( open circuit)36 Rear left sensor ( open circuit)31 Rear right sensor ( open circuit)32 Rear right sensor ( open circuit)18 Sensor rotor61 Actuator motor or motor relay63 Solenoide valve relay circuit ( except power supply for relay coil)57 Power supply (low voltage)16 Stop lamp switch circuit71 Control Unit
