ABS, how can i know????????
MikeS14240sx
Car: 98 Nissan 240SX
I can get a set of 5 lug hubs off a 95 SE for cheap. Problem is if the car has abs i won't be able to use the hubs on my car without abs(correct?). If the 95 SE has abs well there be wires running to a plug on the spindle assemble somewheres like other car makes with abs?
Sorry if anyone feels there intelligence has been affended by my seemingly stupid question to your vast knowledge but i'm not familiar with nissan abs systems:)
Thanks for any help.
GodDrivesA240sx
Car: 1995 Nissan 240SX
MikeS14240sx wrote:I can get a set of 5 lug hubs off a 95 SE for cheap. Problem is if the car has abs i won't be able to use the hubs on my car without abs(correct?). If the 95 SE has abs well there be wires running to a plug on the spindle assemble somewheres like other car makes with abs?
Yeah I'd imagine there'd be a abs sensor somewhere, You can also look at the M/C it should have another line running off of it IIRC.
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
MikeS14240sx wrote:Sorry if anyone feels there intelligence has been affended by my seemingly stupid question to your vast knowledge but i'm not familiar with nissan abs systems:)
AHHHH MY IQ
hehe j/k easiest way to check abs is to look on the passenger side in the engine bay on the firewall. You would have a thing (cant rem the tech name, abs actuator dont have abs so I never really looked into it much) that looks much like the master cylinder of a clutch or the brake MC part right there, with lines going down to the brakes and to the brake MC.
Easier is if your car is an s14 base it doesnt have them as it wasnt an option IIRC on base cars.
Also you can use abs hubs on a non abs car. Onlt difference is that there is a abs sensor cog around the hub and has the sensor on the spindle. Disconnect or remove the sensor if you wish. Then if you can remove the sensor cog or gear inside the hub if you want but it makes no difference either way.
Only thing is taking a non abs hub and putting it on an abs car you will need to swap these parts into it, is all.
red240ne
Car: mmm...donuts
easiest way is to look at the ABS light on your gauge cluster...
GodDrivesA240sx
red240ne wrote:easiest way is to look at the ABS light on your gauge cluster...
But the fun way is to go find a nice huge puddle of water.
:yesnod
edit: low on sleep :doh :doh must consume more :beer
96_S14_SE
But what if it burned out :)
Better to burn out than fade away...
milo
I like the puddle idea...
Mayhem_J30
Car: Ummm...My Car
try hitting the brakes in a parking lot of ice. if it makes a lot of noise before you run into something then yes, if you just run into something without noise then no.
stickgoat
In my experience ABS doesn't really make noise, you just feel a lot of vibration from the brake pedal. It's kinda neat. :) Even neater when you stop and you don't think you're going to.
redrocket
Car: 1987 Nissan 200SX SE
2007 Chevy Silverado Classic Crew Cab
1999 Kawasaki ZX9R
this is the ABS in the engine bay
96_S14_SE
A picture is really worth a thousand words, no? hehe
MikeS14240sx
Thanks guys for the responses. I forgot i even posted this thread.
As for the puddle idea the car is without an engine in a junkyard.
