ABS good or bad for drifting?
D1GP
Car: S13
is abs good or bad for drifting? if it's bad is there anyway to disable it?
TrueSlide
Car: Stuff
its fine, just prevents brakes from locking up.
Cyberkreig
Car: 1993 Nissan 240SX SR
ABS is a good thing to have in winter and rain.. I dont like it.. think its glitchy... To drift, simply remove your ABS relay.. Makes lockingup tires easier.
Holisticbeatz
yea, what Cyberkreig said...
Flipflop
For avoiding small animals in the rain, it's great.
I think it's bad, bad, bad for drift. When you hit the brakes or yank the handbrake to lock the rears when setting up for a corner, the ABS kicks in and tries to make you straighten up.
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
Flipflop wrote:When you hit the brakes or yank the handbrake to lock the rears when setting up for a corner, the ABS kicks in and tries to make you straighten up.
Brakes yes, e-brake no... When you pull the e-brake it manually pushes the piston assembly out. No hydraulics are used, thus abs has no effect on it.
