has any body been able to pull codes from ABS using the data link connector . grounding "l" terminal as stated on the FSM . I've tried several times sticking a wire into the lavender/white wire at the DLC them grounding the other end, no luck. I cant get the ABS light to blink or am I grounding the wrong wire? and which color it is ?
I have my car running beautifully now after doing so much work replacing timing belt , water pump , alternator ,starter , fuel injectors oil pan gasket redone , egr tubes cleaned out ...the only thing its I cant get rid of this freaking ABS light...
