ABS/brake noise
dameianm829
Car: infiniti 2012 m37
I am having an issue with my brakes. While driving i can hear a humming noise, when i brake i hear loud noise only with windows up (windows down can't hear it that much). Took to my mechanic and he says it's the ABS pump...i took it another mechanic he says it's the pads. I had this noise since last year and it's not so bad in the winter but summer/hot weather it's worse. So last week i had the front pads replaced and the noise did not go away. I want to remove the ABS fuse and to see if the noise goes away. I opened the hood and found the fuse box but i dont see a fuse that's for ABS. Any help would be appreciated where to find the ABS fuse and noise issue.
Ilya
Welcome to the forum. Does the noise only come/go with brake application or does it get louder/quieter with turning of the wheel?
dameianm829
get louder as you apply brakes. In winter not so bad i can still hear it. Do you know where the ABS fuse is?
Ilya
No, but if you download the factory service manual (FSM) off this site, you should be able to deduce it's location. The link to the FSM is in my signature (FAQ).
dameianm829
thanks i have the manual and cant find it..i also called the dealer and they said the same thing but it's not listed under the idex...i have gone through it many times. If you can find and send will be greatly appreciated.
dameianm829
this car is nice but the one i have is a lemon...so many issues and i spent so much money on it. Ive owned a Maxima and Altima and didn't have this much issue. With a Luxury car like this, thought it would be build better.
Ilya
The ABS system is described on page EBC-31 and the fuse/relay breakdowns are on page PG-131 onward.
Also, in case you misunderstood...
Factory Service Manual =/= Owners Manual (what comes with the car). You either have to buy it or download it. NICOClub provides it for free to all members. Again, reference the FAQ/HowTo link in my signature if you need to get it. Again, sorry if I misunderstood but looks like you might be referring to the owners manual.
dameianm829
Thank you...yes i don't have service manual. Will have a look. Thanks again for your help
