ABS autobleed
2015roguesl
Car: 2015 Nissan Rogue SL Silver
Hi
Trying to find out if Nissan has autobleed (is autobleed programmed by Nissan, can the OEM Nissan scan tool do autobleed, can auto-bleed be done by a aftermarket scan tool)
Have a 2018 Nissan Rogue SV premium.
I can activate, turn on for 3 seconds individual ABS solenoids, with my $99 Thinkcar Thinkdiag scaner/dongle/app.
But I don't see auto bleed function.
The Thindiag app sells a $45 yearly autobleed option, but if Nissan doesn't do autobleed, the manufacturer says autobleed won't work.
So anyone ever use a scan tool on a 2018 Rogue?
I also have a 2015 Xterra, and 2015 Rogue also I am interested to know if autobleed function works.
Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
No autobleed. If only the ABS or master are being replaced, you can bleed out the individual fittings at the ABS using on/off work support for each solenoid. If anything downstream is being replaced you should disconnect the ABS and bleed the system the old fashioned way. You can find out all about your brake systems here:
https://www.nicoclub.com/service-manual ... 5%2Fbr.pdf
https://www.nicoclub.com/service-manual ... %2Fbrc.pdf
Return to “Rogue Forum”
