ABS/Anti-Skid
bentrod
Car: 2014 Q50 AWD and 2003 G35
Last week while driving at about 30 mph, I failed to maintain a proper lookout and found myself in a panic stop. The good news is I did not hit the car in front of me, the bad news is that the car's rear end swung around to the left about 30 degrees and the tires seemed like they were in full lock-up. Is this a matter of concern? I always thought that the anti-skid and ABS brakes would stop you in a straight line. (I have a 2010 G37x w/ 15k mi) :gotme
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
It should stop in a straight line but also depends upon the road condition, the brakes and suspension. At 15K miles, more likely the road condition or the brake.
zozoka1212
Car: 08 Infiniti G35x
It shoud of stop straight. I even do it sometimes at winter time when I get out and do some quick steering right left and hard brake. All at low speed and as soon as I get out of my driveway to make sure I know what I am dealing with. Neever had any problem.
How good your brake rotors and pads are. Maybe one is locking up.
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
should stop straight... i have the same car... been in a couple panic stops in a year... always straight so far...
Where you turning the wheel? cause the abs will help you steer the way the wheel is turned...
audtatious
You should not be having an issue with the rear end kicking out. The G37's have a 4-wheel/4-channel/4-sensor Anti-lock Braking System and should adjust each wheel accordingly.
Can you replicate the issue? Trip to the dealership would be the next step.
