240-slide-ride »
https://forums.nicoclub.com/240-slide-ride-u79396.html
Tue Jul 01, 2008 9:00 pm
ive got a 93 240sx se with abs, and i just picked up a welded diff for a temporary thing. i just pulled by pumpkin out and realized that it has a abs sensor in the front where the driveshaft bolts up and the welded diff doesnot. my question is will there be problems with my drive shaft since the abs pumpkin is a tiny bit longer than the welded one? also is a way to just swap those shafts in the pumpkin where the driveshaft bolts up to? because those are what are longer. thanks alot
