Post by Silvia92 » https://forums.nicoclub.com/silvia92-u142878.html Fri Sep 18, 2009 8:23 pm
Post by Shabbernigdo » https://forums.nicoclub.com/shabbernigdo-u43872.html Fri Sep 18, 2009 11:29 pm
if i rember right the abs rotors are slightly bigger then the non abs rotors.Silvia92 wrote:Can I run abs drilled slotted rotor on a car that does NOT have abs (non abs)? I mean I just want to use the rotor, do not care for the sensors since i Dont have them. Do i have to worry about the type of pads, caliper (pad carrier), or clearance of the rim or anything?
Post by Silvia92 » https://forums.nicoclub.com/silvia92-u142878.html Sat Sep 19, 2009 1:59 am
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
