ccampbel1 »
https://forums.nicoclub.com/ccampbel1-u171736.html
Mon Dec 20, 2010 6:36 am
Some more follow up information.
Drove across town Friday night, had error. Saturday & Sunday, Drove 1000 Km, (~600 miles) on freeway car did not error out once. This makes me think it's heat in the brake system related, in town always on the brakes, takes 15 minutes to happen (time for brake system to get warm in city) But on the highway, no failures as the car is running with lots of air and not much heat in the brakes. Also I tested the brakes with the failure indicated on the dash Friday and the ABS still seems to work fine, I have pulsing on at least some of the wheels ( didn't get out and check if 1 wheel was dragging). It just prevents the stability, cruse and rear steering from working. I also checked brake fluid levels, the are all fine and the fluid is pretty clean looking.
Based on me thinking it's heat related, on Friday I checked the ABS/brake units to see if they were hot after the error came on, but they are all cold to the touch at least on the outside.
At this point, If I could get confirmation part numbers, I'd just order a used unit. Error hasn't driven me crazy to the point of a 3000 buck repair (yet).
