ABS - 4WD - VDC WARNING LIGHTS
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
hummer3t
Car: 2013 Infiniti QX56
2013 QX56 153,000 miles. Driving to work these three warning indicator lights came on and remained on for the 20-minute drive. When I left work the lights remained on and during the 20-minute ride home they "all" turned off. Been over a week without a reoccurrence, until today. Today, all three warning lights came back on for the drive to and from work. Any ideas?
hummer3t
Here's the latest: the ABS & VDC Warning Lights seem to be permanently on, but the 4WD warning light is intermittent. Haven't found a solution, obviously it's an electrical issue, and fortunately I don't notice any change in the vehicle performance.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You won't get anywhere without a scan. There are only about a million things that can cause an ABS Christmas tree. If your scanner won't do ABS and transmission, most free scanners at the parts store will.
hummer3t
I didn't get any fault codes on my scanner, can't recall if it scans ABS or transmission. Will get back on this.
hummer3t
Had a scan completed today and got the following codes;
POWER TRAIN SYSTEM: P1557 Battery Temperature Sensor, Secondary DTC's P0725 Engine Speed Signal
ANTI-LOCK BRAKE SYSTEM: C1118 4WD Error, C1105 Rear Right Sensor 2
PalmerWMD
Car: 2004 350Z
hummer3t wrote:
Sat Sep 16, 2023 9:54 am
I thought it might be one thing easy to interpret.
but looks like we have to wait for VStar to chime in. :whistle:
VStar650CL
Technical Expert
The C1105 is probably causing all of that except the P1557, which you can pretty much ignore. There's a problem with your righthand rear ABS wheel sensor.
hummer3t
Working on the ABS problem.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
