uvamosk »
https://forums.nicoclub.com/uvamosk-u30063.html
Thu Aug 30, 2007 3:12 pm
So, Anyway for reasons I can't say I had a 2.5" exhaust put on and I have no Cat no resonator.
I now have a straight through exhaust with no bends almost what so ever.. and a straight through muffler... Its all a long story...
anyway
Well since the install I have had back firing issues which I knew i would seeing as I have no back pressure.
The problem I am having though is when im around 4k and gun it WOT It will accelerate very fast then at random will cut out and some times backfire really loudly... You can feel the lose of power. I am curious as to if this could all be cause by the lack of back pressure as I never noticed this problem before the exhaust was put on.
It drives fine normally and haven't had problems with it cutting out if I keep the throttle around 3/4 the way when I gun it.
This kinda makes me think it may be the TPS or something since I have idle sticking issues... that I cant tune out with the Idle control valve or timing at the Distributor. (Although I have also searched for vac leak but cant find anything. )
IF anyone has any kinda suggestions to check or comments let me know.
I was going to just redo the exhaust but since I'm swapping RB20det in I'm not to worried about it just kinda would like to figure out whats going on because it drives me nuts when I step on it in traffic and it takes off then just starts cutting and POPing...
O FYI. The engine is a SR20de... I posted in KA forums because its the closest thing to the sr20de since it has distributor ignition system.
Thanks guys.
Modified by uvamosk at 6:18 AM 8/31/2007
Modified by uvamosk at 6:20 AM 8/31/2007
