DrifterTom »
https://forums.nicoclub.com/driftertom-u32930.html
Fri Mar 03, 2006 4:06 pm
sounds like you may have a few places to look. you need to start eliminating possibilities.
maf wiringboost/vacuum leak (most likely)tps i have had a boost leak that would be intermittent and do allkind of weird stuff.build the boost leak tester that one of your rb forefathers did a right up on.every home mechanic that is dealing with boost should have one.i have found numerous leaks as well as a cheap intercooler clamp
