TDot wrote:Please feedback.
Must: sub be free air (I plan on putting it in the trunk pass through, I DO NOT want a box in the trunk). Prefer: Amp class be A/B.
So this is my planned setup:
1/ Infiniti Kappa 62.9i Speakers (all doors)
2/ Rockford Fosgate 3Sixty.3 Processor (go great with the computer mod)
3/ Boston Acoustic G310-4 Sub
4/ The amp is where it gets a little complicated for me. From reading up on specs I want to go with a class A/B and stay away from D for the poor audio quality. Am I giving that too much credit? Also, I prefer a high SNR. I dont know how much it matters in a car, but when I used to build studios, I made sure nothing was below 110 SNR) Which of these should I go with, or if you have a suggestion?
a/
MB Quart ONX4.80/500 (The specs seem perfect, but I've never heard of this manufacturer before and the price to specs seems too good to be true)
b/
Rockford Fosgate P1000X5D (Great SNR 105 FR/95 Sub, but class D)
c/
JBL GTO-5EZ (Low SNR 85)
d/
Polk Audio PA D5000.5 (Great SNR 105, but class D)
e/
Alpine MRX-V70 (Low SNR 85, and class D, but fits the bill)
Any and all suggestions. Thanks.
Here's my suggestions of what worked for me. Note, this is with the Advanced Tech setup (14 speaker w/Bose amp). I'm not sure what audio package you have (6, 8 or 14 speaker), but the application is the same.
1. Door Speakers - I would suggest upgrading to a better speaker system than the Infinity's. My rear Infinity Kappa's are not very good as they don't output very much sound at all. You can get some JL's, or in my case, I got the Focal 165 KRX2 for the fronts (came with tweeters as well), which sound like a symphony hall all around me.
2. Processor - I didn't have to use any type of computer signal processing. The Bose amp already processes the signal, but if you want to be able to tweak the signal to your complete liking, go for installing a signal processor. I'm okay with a flat sound.
3. Sub - As for your requested "Must", it seems like if you purchase that Boston Acoustic G310-4 sub, you won't be able to achieve your free air setup that doesn't have a box. I've seen open air sub setups, but that is with a much bigger custom fiberglass-type enclosure. I have tried an 'open air' setup of installing slim open air subs in the trunk sub enclosure, and that did not work out well at all, to say the least. I purchased the JL CVS110RG-W6v2, which is a really small sealed enclosure, but I wound up overheating the voice coils after about a year of use. Basically, if you want good bass that will
last, you'll need a good sub, like an Alpine Type-R or up - my Alpine Type-X 10' is super tough, has great harmonics and has a 3000W max limit, so I can push it harder/run it longer than any other sub I've used. Having a friend (or yourself if you are handy) build you a custom enclosure based on the specs of your sub and trunk will yield very good results.
4. Amp/Signal to Noise Ratio (SNR) - You can get any amp you want (A/B, D, whatever), but...a class A amp runs the hottest and are usually pretty bulky. Class AB's run cooler. Class D amplifiers produce higher distortion than AB designs due to the high-speed switching on and off of the transistors, but this distortion occurs at high frequencies that are typically removed by a low-pass filter. I use those filters to produce the best sound for my ears after physically setting up the sub. Due to its design, they run the coolest as well. Class D is great because most amp bodies are slimmer than other classes, and the one I have doesn't have any fans (it is cooled through the 1 1/2 inch long heatsinks attached to the amp). I purchased a class D JL HD 900/5, thinking I could use all 5 channels, but learned that the Bose amp/Infiniti system's voice recognition is tied with the channels, and did not want to risk losing those features just to put the other channels to the JL amp, so I just used the subwoofer channel, and connected that. If I did it again, I would have definitely purchased the JL HD 1200/1 monoblock amp instead of the JL HD 900/5. If you want very low signal to noise ratio (SNR), install a flared port tube (makes the sub box ported). The flared port tube makes my sub sound even better, and is devoid of any SNR issues.
I hope this was of some help to you, good luck, and let us know how it goes.
