Not that it's a big deal... but just to be clear on something.
We decided in a previous thread that while the E-E do lower the engine and work very well, they still do not allow you to use the a strut tower bar. The RB20det from a skyline gts-t has a blow-off/recirc valve attached to the crossover pipe. That valve sits right in the middle of where you need to put the strut tower bar even with E-E's mounts.
You can get around it one of two ways.. A.) Get a cefiro crossover pipe and an aftermarket blow-off valve. The cefiro didn't come with the blow-off/recirc valve stock, so it has a clean pipe that leaves room for the strut tower bar. You can use the R32xmember with stock mounts to make this work B.) Get a triangulated strut tower bar that attached to the firewall. They are much more expensive, but are better than the normal straight bar because they give another point of connection and really stiffen the chassis.
