about to replace transmission and found fried clutch :-(
dsylvia
Car: 93 hatch
last october i blew the transmission in my S13. the transmission was crappy anyways so it inevitable.
well me and a friend finally dropped the blown transmission to install the rebuilt one. after lowering the transmission we inspected the Clutch Masters stage 5 clutch and found that the spline were gone. friggin figures. heres some pics.the clutch has less than 1000 miles on it. so needless to say, im a little pissed, lol. i really dont want to get another CM so im open to suggestions on a better setup.
j-z
Car: 95 240sx
WOW have you contacted CM? maybe a defect?? or maybe cause your transmission blew. who knows.... i know ACT is good as well as SPEC. btw how much power were you making when that happened?
s14det
If the clutch looks like that, what does the spline's on the shaft look like? I have never heard of that before. I would call CM and see what they can do for you? Never hurts to try
dontbugme
When the transmission failed, what happened? Did it lock up? Give us a clue as I doubt it was the clutch plates fault.
Chezedik
Car: 1991 Nissan 240sx
Bad Pilot bearing? It looks as if that has been milled off, as if a spinning shaft suddenly contacted it. Kinda like a starter leaves marks on the flywheel. Anyway, that is my $.02.
dsylvia
Car: 93 hatch
i called clutchmasters the other day. they said its not a common problem so i have to ship them the clutch so they can inspect it. from there they'll decide what they feel they should cover. we'll see how it goes.
on a side note, i ordered an RPS clutch. 2400lb clamping force, 6 puck sprung, holds up to 475tq
