RatedR »
https://forums.nicoclub.com/ratedr-u4104.html
Fri Aug 08, 2003 5:54 am
Dude, we're really miscommunicating....The transmission drain is right under the CENTER of the transmission. I think the bolts you refer to are the crossmember bolts. The drain plug is a big bolt that has a square hole into it. Just use a big socket wrench (1/2) and take it out. The one on the right side is the "proper" filler hole. Kinda hard to get out if you dont have a bunch of allenhead sockets..... just fill it through the shifter hole (2.5 - 2.8 quarts). Questions, just reply. I'm actually just finishing up my new clutch, so all this stuff is still fresh`!
Janeh'~!
-R
