About to pull trigger on new wheel could use feedback...
mikeym45x
Car: 2008 M45x
Saturday I might be getting a set of 20s, for my 08 m45x, Lexani LX-10 polished with a black lip, I really waned to do staggered but don't want to risk it. So I decide to go with 20x8.5 all around with a 38mm offset, and 255/35-20, they should fit with no rubbing, as someone in here posted there car with 255/30/22 all around on 9in wheels and he said he had no rubbing (and those tires are a full inch taller overall then the ones I'm getting. I really wanted that flush to the sides look and also since i cant go staggered wanted to go as wide as possible so I am going with 255's. I might lower it later on depending on how much the ride quality is affected with just the wheels. Any opinions would be appreciated before I do it, thanx. They guy at the shop is willing to try the 255s on the front first to make sure and if they dont clear I'll go to the 245... Oh and my car is black and here is a pic of the wheels.....
FndMspot
Car: 2007 M35 Sport
Lexani makes nice wheels, almost went with this setup, check out the two tone wheels from Vossen.
mikeym45x
Car: 2008 M45x
hows the prices on the Vossens compare with the Lexanis? I like the vvs082 alot but not sure if i can run a 9 all around
FndMspot
Car: 2007 M35 Sport
Prices are very similar, and yes, but check with your wheel installer, should be ok on the 20x9.
mikeym45x
Car: 2008 M45x
ok thanx alot, I like the vvs082 in full silver alot! I called them they said no problem 20x9 all around 38mm offset, I'd still put the 255/35-20s on. problem now is the guy im buying from wants 400 more then the Lexani's, so I gotta shop around.
