About to install tein tie rod, tie rod ends, and front control arms
lazyfcker
Car: 1991 240sx hatchback
I was just wondering, if i will need any special tools to install these parts this weekend?
180fan
Car: 89 fastback
pickle fork to pry the tie rod end off from the knuckle. When you reassemble your tie rods, be sure to count the turns, not the threads. You want to get as close to your original alignment as possible so you don't drive crazy and crash. Also after doing this, get an alignment, not really optional unless you want your alignment to be jacked up.
lazyfcker
Thanks for the reply! and.......i was also wondering if anyone knows where i can get an install guide to help me install the front control arms...thanks
