HigherRhymes »
https://forums.nicoclub.com/higherrhymes-u88507.html
Sun Aug 30, 2009 6:02 pm
So I've finally made enough money to make the first big leap on my project car before I start my major mods. First step was to convert auto to manual, before suspension, body work, and engine get a make over.
So first things first, I don't have the tools or the space necessary to complete the swap. So I am having my good friend's shop do it now that I'm back in college. But before I leave them with my car I have a few questions that I haven't been able to find answers for.
1. My car is a 92 DOHC auto, power everything. The donor car I bought is a 90 SOHC, power everything. Should I make sure the harnesses get swapped to insure the ECU and all my goodies (defroster, cruise, etc) work properly? (Engine diag., CEL, etc etc?) Most swaps I've seen require splicing (for starter and brake lights, and others) I am not a wiring expert and I'm not familiar with what wires they're jumping and if its safe or has any adverse affects...
2. Will I need to pick up an ECU from a 91-93 DOHC ka24de or will the SOHC ECU I have work? Just by looking I can't tell the difference... but I am aware they have different part numbers.
3. Since the drive shaft, and gearbox will be dropped is there any parts I should buy to ensure my swap holds up for the long run (besides clutch/flywheel) [IE: the pedal assembly and linkage is metal in the 240s as apposed to the EVO X having problems with the plastic accelerator and clutch pedal snapping ] any parts you would suggest I make sure get installed?
4. How much hp can the stock two piece drive shaft hold? I'm looking for about 325hp to the wheels after all the work is completed, I've searched and the average consensus is around 400hp.. but not safely. Should I get the stronger and lighter single piece aluminum drive shaft?
