About to do a SR20det swap into my 93 s13
Theways2go
Car: 1911 nissan 240sx
I did my research and I still need some help :confused: . SO i am decided to buy a sr20det engine and i did the research with what it need for a complete swap. I just wanna check with you guys if I have everything or I still need something or I am missing something or comments on where I am heading, Thanks. Here are the list of stuffs I got so far:
Jdm Engine Sr20 Turbo S13 Red Top 91-93, some are engine & trans parts but I list it anyway :biggrin:
1.Manual RWD Trasmission
2.Clutch
3.Flywheel
4.ECU (computer)
5.Complete harness wiring
6.Ignitor chip
7.MAF sensor
8. A/C Compressor
9. Alternator
10. Complete Block
11. Distributor
12. Intake Manifold
13. Complete Head
14. Power Steering Pump
15. Coil Packs
16. Cam Angle Sensor
17. Starter
18. Throttle Body
19. Exhaust Manifold
20. Fuel Rail
21. Injectors
22. Turbo Manifold(s)
23. Turbo Charger(s)
24. Pulleys
25. Fan
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
You will also need:
Side Mount or Front Mount intercooler with piping
Stock or Aftermarket BOV ( Blow-Off Valve)
If you are using A/C compressor you will need to make custom lines for it to work on your USDM body.
Downpipe, testpipe/CAT, exhaust.
Boost gauge, Air/Fuel Gauge, Oil Pressure Gauge.
Manual or Electronic solenoid Boost Controller ( not needed but if you plan to run a little more boost than stock 7psi)
Bigger Radiator than the stock Sr or KA one.
If you really want to be sure to get a complete swap. Get a whole front clip from a Silvia/180sx. It will cost you a little more, but you will have extra bolts and nuts when you need them. That little stuff adds up quick. Usually with clips they have aftermarket as well as stock parts. It all depends. I would get one that is near stock as possible.
Theways2go
Lobo240sx wrote:You will also need:
Cool, I need a lot more components :yesnod . I already brought a full exhaust system and the Side Mount or Front Mount intercooler with piping.
Where can we find the whole clip from a silvia/180sx? upon my research, i didnt come across it. much appreciation for the help.
Lobo240sx
This is just an example of a front clip. I do not recommend buying engines from ebay unless you have thoroughly done some research on the seller and company.
http://cgi.ebay.com/ebaymotors/Jdm-Niss ... ccessories
Take a look at this thread also.
where-to-buy-sr20det-engines-t126440.html
