Why do I need the 300ZX Thermostat? Does the stock RB20 one not cut it, or what..?RustspecS13 wrote: You'll also need a Z32 TT thermostat. Normal temp is fine for a street car/daily and low temp is a good idea if it'll see track time.
Cat backs are chassis specific not engine specific. You will need a RB-schassis specific down pipe. I made my own. You can also get a psyko (sp?) down pipe that bolts to the rb turbo. Its 3in and has more steering shaft clearance then normal and also uses a super common sr20 down pipe.
JSPECAUTO.com, i meant to put 1.2k...no clue why I listed it as 1000.Lonismos14 wrote:I read some where that you can only use the r32 crossmember if your motor comes with the r32 motor mounts.Im ordering my motor today where are you finding yours so cheap from?
Carl H wrote:skip the cas, oil pump, and pickup...spending money you dont need to.
i have had good luck fitting the CXracing r32 gts-t/r radiator to swapped cars, it sits a bit tall but it fits under the hood just fine, you'll need a spacer under the mount brackets but its ok as is.
not to mention last one i bought was 140$ shipped.
a good set of fans and a new z32 tt GENUINE nissan thermostat along with the waterpump should keep it reasonably cool.
Got it.RustspecS13 wrote:The strainer and cas are not needed.
I would still recommend the oil pump, as they can wear out on the part that contacts the crank and these engines have oil problems. Its $100-160 or so and its cheap insurance. Just like the T stat, they are just simple metal springs and after sitting for years with some coolant rusting away in the block, the one in the motor set is likely junk.
And I told you you'll need 2 pusher fans, mean in front of the radiator pushing air through it. A pair of 12-13in is the most common setup.
~Alex
This radiator setup was also ran in my car, never having a single issue.Carl H wrote:skip the cas, oil pump, and pickup...spending money you dont need to.
www.jhotimports.comStryfeS13 wrote:
Also, does anyone know a reputable source to buy an rb20 from?
I went with two 12" fans. One pusher, one puller, and I staggered them.StryfeS13 wrote:Brennan, what size of fan is the most suitable?
So as I said call, they have a list of motors coming in the next shipment always. Would you rather have a good motor and have to wait, or get one that might be sh*tty? I think I'd rather wait...the one I got from them was in MINT condition when I tore it down. Also came with a lot of sh*t.StryfeS13 wrote:I don't really understand JHOT.
Do I basically need to lurch the website and wait for an RB20DET to arrive, and then call and reserve it/buy it? I'd rather just be able to buy the engine at any time....
And the ebay store never has inventory of engines, either. Except STi motors, 4AGE's, and rotary disasters.
