dontaskwhoiam2001 »
https://forums.nicoclub.com/dontaskwhoiam2001-u88726.html
Thu Sep 01, 2011 4:50 pm
Hi all,
I am about to buy a FX45 2008 from a well known local dealership. I would need your opinions if any.
It's on 74000KMs, fully loaded, it has all options you can think of.
It's so called "Infiniti Certified" - I was showed the "Certification" work done in April on its 71000KMs. The work includes the followings
- pre-owned check over
- four wheel computer alignment
- replace front brake pads, rotors and hardware kit
- replace rear brake pads, rotors and hardware kit
- Inspect brake lines and flush brake fluid system. Replace brake fluid and bleed system as required. Bi-annual brake fluid service
- Flush "J" Matic transmission.
- replace two drive belts
- drain and fill transfer case. Front and rear differentials. Inspect for leaks and axle conditions
- Perform regular scheduled maintenance. "C" service
replace engine oil and filter
lubricate all locks. latches, hinges and steering stops
rotate tires
- replace wiper blades
Total parts ($1150.84) and labor ($1349.33)= CAD$2500
I have two concerns about this car
1. Its high mileage
Would you consider 74000KMs high for this car?
2. The price
They are asking for CAD$38,888. How's the price sound to you?
3. Any other comments?
Thanks
Jack
