Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Jun 22, 2005 5:29 am
if your air compressor can't deliver the air pressure the gun needs to operate, it just sits there wheezing instead of working. Most compressors will rate their effeciency rate, and as long as you don't go with a small mini-compressor with a 1/2 hp motor, you should be fine for most apps.
This shop I used to frequent a lot and do some work on my car had this huge industrial strength Ingersoll/Rand compressor. And of course, we only had one gun working off of it. That sucker would tighten any bolt to the "how the crap do I ever get this off again" level. It's also the reason I don't trust air compressors and torque sticks with lug nut duty. I prefer the old fashioned torque wrench.
I've used Snap-On's 1/2" electric impact gun at auto-x events (we would "borrow" it from my friend's boss [the guy with the I/R compressor]) and it works very well. The only issue with it is that you have to help it loosen lug nuts. It doesn't deliver enough reverse torque break a 90 lb/ft lug nut loose. Basically, we'd turn it on, and help turn the socket to get it to break it loose.
