do you know what 600rwhp involves? walbro fp's are pretty unreliable, if they tell you they need to be replaced every two years, why would you run them?addicted4life wrote:Been reading around about injector upgrades and am kind of fuzzy on the details with upgrading and the new/old style, whats size is compatible with what , as well as 300 degree fuel rail setup. I understand a little but basically what im trying to do is build my car for about 600whp in the distant future (am still toying with the idea of single big turbo if that matters) I'm upgrading my fuel system a little while I have my motor out for the rebuild. Already have new walbro fuel pump, but what should I be looking for when it comes to injector setup? 300 degree rail? Nismo, Sard injectors (after a little research I want new,not reman or drilled) ? Any special lines for 300 degree fuel rail?
Thanks guys
Brad
right, but the jecs themselves are redrilled, tougher to tune.NolimitZ32 wrote:Sidefeeds - Jecs (who make OEM injectors 120cc-880cc IIRC) and yes they make nisoms too
i understand that, Anton, jecs makes oem injectors and even nismos.NolimitZ32 wrote:No they aren't, JECS is a manufacturer of injectors, worldwide OEM manufacturer. They provide large fresh, brand new injectors to lots of auto manufacturers, I'm trying to find the site right with a catalog of sizes but I know for a fact that they make a new (not redrilled) 800 something cc injector, which is a pintle-less injector with a wide open cap.
Tony, the factory yellow sidefeeds in your legacy are JECS 520cc, same ones that were in my swapped bugeye, same ones i just put into the Z. stock, not redrilled, comes in the car from the FHI - Subaru Division plant in Gunma.
they (the bde's) also come with fuel injectors, probably the best available (injector dynamics) so they're about the same price if you were to get nismo740cc fuel injectors with the 300d fuel rails, etc.addicted4life wrote:I think the boxes are just extra to make them low impedance so of no use to me. Do I need bde or will 300 degree work? Ill never use the bde to its full potential and it seems to be about $1000 more then the 300 degree everywheres I look
Thanks for all the help guys
