SHIFT_COUPE wrote:1. Push the ignition switch to the ON position.2. Open the window more than halfway byoperating the power window switch.3. Pull the power window switch and hold it toclose the window, and then hold the switchmore than 3 seconds after the window isclosed.4. Release the power window switch. Operatethe window by the automatic function toconfirm the initialization is complete.5. Perform steps 2 through 4 above for otherwindows.
Tyler, since this and the airbag light are common problems, is there any way you could post them on the READ FIRST page, that way every noob that disconnects the battery will know how to fix them!
