About the Speed cut again
red240sx sr20det
we have established the speedcut and to cut the yellow with green stripe wire. Dose it work? i also just got my car back togeather had to put new tubo to manifold gasket on it there was never one in the first place and i ported out my exhaust manifold. and also just put a boost controller on im running 15 psi but then it drop to 12psi on the stock turbo and i also got a hid kit for it they are awesome. so it will be exciting friday to see me hopefully kill my friends srt-4. get back to me on the speed cut defense and if there are any little power gains that i can do for like free. thanks
quiksilvia
Car: 95 s14 se
15psi? what turbo? u still have the stock smic? what kind of bc?
red240sx sr20det
i have the stock turbo and it runs 15 then drops to 12 to 13 and what do you mean by smic and bc??? i donno what that is cause im a dumb ***
quiksilvia
Car: 95 s14 se
stock turbo ist worth much past 14 psi, side mount intercooler = smic, it shouldnt be pushed past 12 psi, bc = boost controller, and if u got a full exhaust, you only need 10 psi to beat the srt 4
red240sx sr20det
i have a 3 inch front mount intercooler and full 3 inch exhaust no cat with 3 inch down pipe but he has a boost controller and is running 14/15 lbs.
quiksilvia
Car: 95 s14 se
turbo shouldnt be pushed above 14psi, im sorry but i have to be honest with you mr red, you dont seem to have much knowledge about this stuff, i could be entirely wrong, but u need to read a lot and know what ur doing before u kill ur 240 :)
red240sx sr20det
no the srt-4 is puttin out 14/15 lbs im putting out like 13
quiksilvia
Car: 95 s14 se
o **** my bad, i read it too fast, if he has a boost controller why is he running at stock boost?
red240sx sr20det
i donno he said tomorrow he is turning it up to 18 lbs i was like whatever have fun breakin it. so dose the cutting of the yellow wire with the green stripe work to cut speed cut?
1mns13
Car: Freedom and cars
No. I found my tach acted funny though when I did.
red240sx sr20det
will the hks speed cut defensor work ??
