Mines like I mentioned in my first post ALL THE TIME. Im not sure its cause of the cold as the hard shift is only when shifting from 1st to 2nd and not during engagement at startup and also all the time even after warm up if thats what you mean. Its very good otherwise in other gears and while decelerating.fueler wrote:and by the way, mine has always shifted hard for like the first minute after a cold start. But smooths out when warmed up. Is that what you're talking about?
Could you tell when the fluid was changed before you did so at 120k?Also, did it run good till 175k or did it show signs of wear before it blew up?fueler wrote:.... I changed mine at about 120k. I noticed that it shifted smoother than before when i changed the fluid (unexpected, since i thought it was smooth already) BUT then at 175k miles....
yes you can change the diffs with pennzoil 80w-90 (thats what the factory uses).ugharin wrote:
I just jucked my transmission fluid. It appeared light brown and very transparent. As in not thick and sludgy.
Should I change the transmission filter and gasket as well? And new bolts? How about the differentials and the transfer case?
Thanks for the help.
FuelerI have a 2001 qx4 and it does the hard shift from 1st to 2nd as you've covered here before but mine also does a looong slip from 2nd to 3rd as well. I usually lift the pedal and let it catch up before depressing the pedal again but I have stayed in the throttle and it slips for a period of time and then catches on it's own. My question is is this a typical problem for these transmission's or would it be something as you said here about changing the fluid? It doesn't do any of the above once the ambient temp goes about 55 which covers about 6 months here. The rest of the year it gives me grief!Thanks for any help you can offer with this!fueler wrote:very good questions. I think changing the transmission fluid is good, no matter what mileage. I changed mine at about 120k. I noticed that it shifted smoother than before when i changed the fluid (unexpected, since i thought it was smooth already) BUT then at 175k miles transmission blew under stupid towing circumstances, i have no doubt in my mind that if i never towed anything it would still be running smoothly today.
I'd change the fluid if i were you. Its probably old, brown and burnt, take out the dipstick and smell it.. I think changing it has potential to help out your 1st to 2nd problem. But no guarantees.
im not familiar with the 3.5 engines as much but i remember reading about a somewhat common problem called "shift flare" in those. Just google "QX4 shift flare" and youll get tons of info about a TSB technical service bulletin on those years.t_b0ne3 wrote:FuelerI have a 2001 qx4 and it does the hard shift from 1st to 2nd as you've covered here before but mine also does a looong slip from 2nd to 3rd as well. I usually lift the pedal and let it catch up before depressing the pedal again but I have stayed in the throttle and it slips for a period of time and then catches on it's own. My question is is this a typical problem for these transmission's or would it be something as you said here about changing the fluid? It doesn't do any of the above once the ambient temp goes about 55 which covers about 6 months here. The rest of the year it gives me grief!Thanks for any help you can offer with this!
I don't think that there was a recall. My understanding of TSB's is that they are for the mechanics to know how to fix a problem. If the vehicle were under warranty, maybe you could get Infiniti to pay. Otherwise, the owner will be paying.t_b0ne3 wrote:I googled it and it was listed in september of 2001 for the 2001 qx4 does this mean there was a recall on it? If so and it was not taken in for this issue how can I get it fixed now? Thnx again!
The TCM is the same, no matter where it comes from, if it has the same part number. That part, I have already replaced.t_b0ne3 wrote:That was what Fueler had talked about in the other thread related to the trans. I don't think it would make any difference what you paid for the updated module as long as it is the same part. $89 sounds almost reasonable for a fix ona factory built problem rather than taking another bath from the same people who made the problem to begin with?!
