? about t28
mixeds14
Car: 240
can anybody in here tell me how much hp can a stock t28 turbo (a/r42) that came of an rb26dett.thanks
lilskyline240
Car: 90 240sx w/ rb30det
one t28? so im guessing u arent using ONE t28 on a RB. So what motor are u using the t28 on? that will totally change the HP output that you could reach
mixeds14
Car: 240
the turbo is goin on a ka24 i have a t25 already in there n the turbo says a/r42 also so whats the difference
lilskyline240
there is a huge difference. On an Rb26 the twin turbos can make around 400whp whereas the rb26 t28 on a ka24 should make around 260ish whp at 12psi. I actually ran that same setup before. Its kick ***
mixeds14
Car: 240
so is it worth 200 bucks
mixeds14
Car: 240
mixeds14 wrote:so is it worth 200 bucks
or should i keep the dsm t25 that i have know until i get a bb t28 wich is what i really want
lilskyline240
yeah its worth the 200 bucks. I was faster with my rb26 t28 setup than my friend with a gt28rs. with the 2.4 liter u are gettin pretty quick spool to begin with. Spooling extremely early isnt needed cuz u just spin
Kalypso
Would a steel wheel t28 from the r34 get up to 350?
with MAF and injectors....
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
My buddy made 232whp on his KA24 with an RB25 Turbo at 6psi. Pretty impressive if you as me.
Newtype
Car: RB26 S14
heres my input on the situation.. use the t25 until you get a ball bearing t28 cause on a KA your probably gonna urge towards cranking up the boost controller and push the turbo.. And the t28 off a RB26DETT is a ceramic wheel and they like to explode when over boosted.. On a 26 with the twins ive been told not to go over 14 pounds and thats with two turbos.. So as a single set up thats scary..
lilskyline240
you definitely woulnt want to run more than 12psi on a stock ka24 block either. Its been done a ton but for reliability i wouldnt go over 12psi. If you want 350whp u better ditch the whole t2 series man. ur gunna need to use a t3/to4e .57 trim at least to get 350whp at 10-12psi
Newtype
Car: RB26 S14
well I just happend to see something last night to help you realize the weak state the t28 off a 26 are in.. At a local shop im friends with they were dynoing a rb26 s14.. I heard he was pushing 16.8 pounds of boost and right there i was like uh oh.. well after working with the afc on the dyno they desided to drive it on the street.. I was standing outside the shop when i heard them start coming back.. As soon as they hit the parking lot i could hear a chattering/clicking noise.. and when they got closer you could hear it really well.. It was coming from the intake side of the head. Once they began to dig into it to figure out what was going wrong they discovered metal blades in the intake manifold and in the head making there way into the cylinders.. what had happend was to much boost cause the wheel to grenade and shot pieces of the wheel into the intake.. the noise was the pieces of the wheel bouncing around on the valves in the head trying to get into the cynlinder.. So think about that.. I'd recommend like a japanese made t3/t4 of some sort if you trying to stay semi cheap.. and if your trying to spend some money then go with say a ball bearing garret gt3037 or gt3071R.. Or possibly a hks gt2835
Kalypso
wow, thats expensive.
... thanks for the feedback
luckily i just sold my rb26 t28,
s14 t28 or save up and go gt2871r.the bigger t3\t4's seem laggier I dont want to loose that smooth powerband.
lilskyline240
the best ka-t setup i ran was a Pulsar GTiR t28. Try to get ur hands on one of those. Really hard to, but DEFINITELY worth the money. They make amazing power with awesome spool time
DriftingisLame
Car: '91 240sx coupe, rb20det
Newtype wrote:well I just happend to see something last night to help you realize the weak state the t28 off a 26 are in.. At a local shop im friends with they were dynoing a rb26 s14.. I heard he was pushing 16.8 pounds of boost and right there i was like uh oh.. well after working with the afc on the dyno they desided to drive it on the street.. I was standing outside the shop when i heard them start coming back.. As soon as they hit the parking lot i could hear a chattering/clicking noise.. and when they got closer you could hear it really well.. It was coming from the intake side of the head. Once they began to dig into it to figure out what was going wrong they discovered metal blades in the intake manifold and in the head making there way into the cylinders.. what had happend was to much boost cause the wheel to grenade and shot pieces of the wheel into the intake.. the noise was the pieces of the wheel bouncing around on the valves in the head trying to get into the cynlinder.. So think about that.. I'd recommend like a japanese made t3/t4 of some sort if you trying to stay semi cheap.. and if your trying to spend some money then go with say a ball bearing garret gt3037 or gt3071R.. Or possibly a hks gt2835
Wow, thats weird that blades could get through the tiny fins in the intercooler.
Kalypso
DriftingisLame wrote:Wow, thats weird that blades could get through the tiny fins in the intercooler.
good point
lilskyline240
thats what i was thinking too. normally the intercooler catches all that
