? about stock wheels 94 Q45
ahardb0dy
Car: 1990 Nissan Sentra, 1994 Pathfinder Se, formerly owned: 2005 Nissan Titan, 1994 Infiniti Q45t, 1987 Nissan Hardbody SE-V6 4x4, 1980 Datsun 310GX
I keep reading and seeing that on the 4 wheel steering Q45's that the stock wheel it should have are the turbine style, but mine has the "piepan"style, was the turbine style wheels just an option?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The turbine wheels came stock on 95 and 96 Qs
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
All 1994 touring models have the Super HICAS rear steering, and came from the factory with the BBS wheels. The other wheel used in 1994, was the clear coated "pie pans" bothe were 15", but the BBS wheels were much lighter, and 1/2" wider.
In 1995, the "pie pans" were replaced with the "turbine" style wheels.
Dealerships were notorious to put Fittipaldi wheels that looked similar to the BBS wheels. Lola came with chrome plated BBS wheels.
16" wheels were not normally used, and tires were few, and not many had the ratings needed for the Q. In 1997, when the second generation Q came out, 16" wheels became the standard. 17" tires were introduced in 1999, on the touring edition. 18" wheels were used on the 2002 models, now 19" wheels are used on the 2005 models.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Jeff Williams wrote:1.) All 1994 touring models have the Super HICAS rear steering, and came from the factory with the BBS wheels. The other wheel used in 1994, was the clear coated "pie pans" both were 15", but the BBS wheels were much lighter, and 1/2" wider.
2.) In 1995, the "pie pans" were replaced with the "turbine" style wheels.
3.) 16" wheels were not normally used, and tires were few, and not many had the ratings needed for the Q. In 1997, when the second generation Q came out, 16" wheels became the standard. 17" tires were introduced in 1999, on the touring edition.
4.) 18" wheels were used on the 2002 models, now 19" wheels are used on the 2005 models.
1.) Bothe the turbine and BBS wheels on my 1995 standard and t models are 15x6.5.
2.) And continued on the 1996 standard model, as noted by Wes.
3.) The 16" wheel on the FY33 was introduced to clear the larger diameter rotor. Recalls were later issued for the 5 broad spoke 17" wheels. First with no lips for weights from Infiniti.
4.) Standard wheels were 17" with 18" optional in US Market. Japanese had only choice of 16" and 17" optional. 19" are only on the Sport model Y50. 19" forged Rays optional only in JDM Y50.
Modified by maxnix at 11:39 AM 7/24/2005
ahardb0dy
so on my 94 touring model it should have the BBS wheels, so I guess sometime between new and now someone swapped wheels
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, somewhere they were changed. Minor problem when you consider there are no good 15" performance tires for the G50 made anymore.
New wheels and tires in larger sizes as good as the BBS will set you back a pretty penny though.
94q45t
Car: 94 Q45T (wrecked), 94 Q45 (healthy), 00 Suburban, 87 Supra mkIII, 98 F150 4wd,
My 94 Q45t and it came with the lace/basketweave design (like the old BBS). I'll check the sticker next time I go to the files.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Check out the Infiniti Cars & Parts forum. There were some BBS wheels for sale a while back. I sold mine.
94q45t
I still have mine. They were not on the car when it wrecked. I can sell them if youo need a set.
