? about stock lifters
c-rad
Car: 1991 Nissan 240SX w/CA18DET
So I was cleaning up my lifters because I was getting ready to install them in the head when I noticed that two of them, when I shake them, they rattle back and forth and I can actually move the lifter with my fingers. Are those two broken or what?
boost_boy
c-rad wrote:So I was cleaning up my lifters because I was getting ready to install them in the head when I noticed that two of them, when I shake them, they rattle back and forth and I can actually move the lifter with my fingers. Are those two broken or what?
They are bad and should be changed!
Dee
c-rad
boost_boy wrote:They are bad and should be changed!
Dee
Figured as much. Good thing they are only $10 a piece new... unless you got any used ones Dee?
sideways danny
Car: s13, CA18DET
where are you getting them so cheap??? thay're £38 each over here
c-rad
sideways danny wrote:where are you getting them so cheap??? thay're £38 each over here
http://www.everythingnissan.com $9.43 each
http://www.trademotion.com/par...gid=1
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
That's good information. But the advice that the lifter is broken may not be 100% accurate.
Hydraulic lifters are not to be stored on their side or upside down..they will get air in them. This is an RTFM fact.
You can refill the lifters, and they are normally assembled in a full oil bath, and done underwater (underoil).
It's possible if the lifters have been empty for a while inside an operating engine, then you may need to get new ones. And at US$10 each..I'd just go do that.
Damn my Solid Lifters are 5 times as much.
Another good thread!
boost_boy
I got good condition extras. Let me know......
Dee
c-rad
boost_boy wrote:I got good condition extras. Let me know......
Dee
Cool. Email a price shipped for 2 good ones to chrisradivonyk AT hotmail.com if you could. Also, could you send them out quickly? I wanted to try and get the head together by next weekend if I could.
sideways danny
Car: s13, CA18DET
dattodude wrote:That's good information. But the advice that the lifter is broken may not be 100% accurate.
that's inacurate info for a CA, I strip every single lifter and I've never once re-assembled them in an oil bath. I believe the CA lifter doesn't get air-locked as they have 2 holes rather than the normal 1. I know SR lifters need to be stored in oil as you get problems if they drain but this isn't so on the CA
