? about fuel injectors.
Nock Out Puppet
Can honda fuel injectors be used in a sr20det? Whats the difference between side feed and top feed? Do all sr20det come in side feed and some people just change them to top feed? Also is any one better than the other?
navysnail
honda injectors proboly dont flow enough if there stock.
side feed- fuel enters from the side
top feed- fuel rail bolts on to the top and fuel enters at the top
as far as i know, i belive that sr20 are side feed stock, and they can both perform the same
Nock Out Puppet
Thanks. The question about the honda injectors is be cause aftermarket ones with higher flow rate can be found cheaper than ones specificaly for sr20det
navysnail
i would go ahead and buy them for the sr20, if they dont fit perfectly, when its under 40-50 psi they are going to leak
Nock Out Puppet
thanks.
