float_6969 wrote:Wait, maybe this isn't a boost cut at all, but an ignition blowout.
How are plugs? Have you looked at them recently? What brand of plugs are they? Coil Packs in good condition? Do you have a spare ignitor you could try? What about grounds? Are you sure they're all hooked up? Do you have the main ground from the battery tray to the intake manifold hooked up? Try adding more grounds.
brand new bcr8 ngk plugs gapped down to .028this motor is in a datsun 510 so maybe i need more grounds i have the battery ground directly to the engine, then from there a 2 gauge cable grounded to the body, ignitor is grounded also. i will def. add more grounds though
im stumped
i was planning on getting a chipped ecu to remove boost cut, but it doesnt make any sense to purchase it if the ecu is only seeing an airflow of about 50% of capacity. my biggest question on the fuel cut part is if there are any other things that the ecu reads that can cause the cut
