First things first - when you put back "the fan that attaches to the water pump", did you also put back the upper & lower radiator shroud?
If you did reattach the shroud, then there is something wrong w/ your cooling system or your a/c system causing it to overheat.
From here, I'd try to bleed/flush the coolant and see if that helps.
Beyond that, you will need to seek professional help or consult the Factory Service Manual.
Roger_cha wrote:well i guess some people id parts different from other people then...
Yea, you and the people you know id parts wrong... This is not a part that is "open to interpretation. Look up what a clutch fan is...
From Popular Mechanics: "The fan clutch operation is regulated by a valve that is opened and closed by a thermostatic spring. The valve controls the flow of a viscous silicone fluid between chambers in the clutch assembly."
How to replace a clutch fan
See the mechanical piece in the center? That's the clutch. There is a thermostatic spring in there (i.e. the controlled part) of the fan depending on engine speed. The fan attached to the radiator just turns on w/ the a/c button & on again when the ecu tells it that the car is too hot - no variable speed. Show me where the thermostatic clutch is on your "fan on the radiator".
