Neejay »
https://forums.nicoclub.com/neejay-u12358.html
Sat Feb 19, 2005 8:38 am
My mechanic said it'd be $500 to replace/install a headgasket kit, water pump, and do a timing chain job. About a month ago, anti-freeze started running from my oil pan, no white smoke, no bogging on startup, just started leaking out the clear blue. I have to buy the parts though which will be about $250 (felpro headgasket kit, OEM timing chain parts, and a water pump from my autoparts store). I got 153 on all 4 cylinders when I did a compression check about 2 months ago (unless I screwed up the test some how).
If Im not gonna be doing any heavy modding, just i/h/e, do you think its worth it to fix this sohc for $750 and have a semi-new engine? People have said to chance it and get a DOHC, but keep in mind I have to pay for labor. The thing is, if I get a DOHC although its newer, nothing would be rebuilt or replaced.
