compression »
https://forums.nicoclub.com/compression-u9345.html
Sat Jan 03, 2004 4:06 pm
You can use head bolts from the N/A sr20de, i.e. B13 sentra, they are the same. They can be bought for about a buck each from Mossy nissan in oceanside, they are a good place to go through even if you dont live in san diego.Make sure you follow the tedious torque procedure in the factory service manual, its a pain in the ***, but you gotta do it.Studding the head isnt necessary unless you plan on boosting over 30psi. I was told this by Mike Kojima, an engineer at nissan that knows the SR engines very well.The main advantage to studding is that you dont load the fastener in torsion like you do with a bolt, only tension.
