Crunkrich »
https://forums.nicoclub.com/crunkrich-u36411.html
Sun Apr 16, 2006 11:25 am
I've read so much about clearing up my rough idle my head has started to hurt with all the different abbreviations, what they mean, and where they are located. Could you say what these stand for, what they do, and where they are located, I've done as much as I know but correct me if wrong. Thanks a bunch
AIV - Air Idle Valve, located behind the stock airbox connected by a short vacuum hose, controls the fuel injection to air ratio (i think this is right)
AAI - ?, located on the passenger side side of the engine below the intake manifold, ?
AICV - Air Idle Control Valve, ?, ?
MAFS - Mass Air Flow Sensor, just past stock airbox, measures amount of air taken in
Are some of these the same and that's why I'm getting lost when reading about them and the material is all similar? If there are any other valves/sensors related to intake / fuel injection a heads-up about those would be awesome, thanks again
Modified by thenameismatt at 7:28 PM 4/16/2006
